Members Kiltzman Posted December 14, 2015 Members Report Posted December 14, 2015 Hi does anyone have a pattern for one? Quote
Members tboyce Posted December 14, 2015 Members Report Posted December 14, 2015 what does one look like? Quote
Members glockanator Posted December 15, 2015 Members Report Posted December 15, 2015 (edited) https://youtu.be/WOpeWQ-UEW4 http://leatherworker.net/forum/index.php?showtopic=27983&hl=%2Bquick+%2Bdraw+%2Bknife This should give you the basic idea tboyce Edited December 15, 2015 by glockanator Quote
Members Kiltzman Posted December 16, 2015 Author Members Report Posted December 16, 2015 Thanks Quote
Members tboyce Posted December 16, 2015 Members Report Posted December 16, 2015 There are so many different makes and models of clasp knives that it would be tough to come up with a pattern unless I knew the measurements Quote
Members Watering Hole Leatherworks Posted December 23, 2015 Members Report Posted December 23, 2015 I'm pretty sure they are typically for a Buck model 110 or Old Henry. I'd love a pattern as well. I'm pretty sure they are typically for a Buck model 110 or Old Henry. I'd love a pattern as well. Quote
Thor Posted December 23, 2015 Report Posted December 23, 2015 This video may explain it a bit better. There's one thing that could be improved. All sheaths of this kind have the cutting edge run over the rivet/stud/bolt, whatever is there... If that would be done with a chicago screw and a plastic or leather washer in between it wouldn't dull the knife so fast. Here's another thread on the forum http://leatherworker.net/forum/index.php?showtopic=42781 Quote
Members Kulafarmer Posted December 23, 2015 Members Report Posted December 23, 2015 If its a pancake style holster they are all similar just vary in where the stitching falls Quote
Members builderofstuff Posted July 5, 2016 Members Report Posted July 5, 2016 On 12/14/2015 at 10:37 PM, glockanator said: https://youtu.be/WOpeWQ-UEW4 http://leatherworker.net/forum/index.php?showtopic=27983&hl=%2Bquick+%2Bdraw+%2Bknife This should give you the basic idea tboyce Hey cool, that's my post and sheath LOL I'm not sure how to scan it and save it as a pdf so that it comes out accurately. Chris Quote Just a man, a shop, and a long list of unfinished projects..... My Website My Etsy Shop
Members builderofstuff Posted July 7, 2016 Members Report Posted July 7, 2016 Here's my pattern that I used to make the one in the post that was linked above. When I made mine I used two layers of 4-6 oz leather so I had a finished surface on the inside and out. Where the two rivets go I cut small pieces of delrin tubing so the blade didn't ride against the metal rivets. It'll keep your blade sharp much longer. For the belt strap again it's two layers of 4-6 oz and it's cut long enough that when it wraps around the sheath there is a bit of gap, and it's only stitched at the ends, that way you can where it anywhere on your belt and have it facing either direction. Hope this helps. I did a test print to make sure that the pdf came out to the right size when printed. Chris www.builderofstuff.com quick draw sheath.pdf Quote Just a man, a shop, and a long list of unfinished projects..... My Website My Etsy Shop
